only one spark **** PLEASE HELP ME*****
Old Mar 4, 2010 | 09:54 PM
bielskia's Avatar
bielskia
Unhappy only one spark **** PLEASE HELP ME*****
ok I have a 2000 plymouth neon I had to replace the engine because it got water in the intake. Well after replacing the cam sensor and the coil I am still not recieving no spark for the coil. I have the timing set right and everything the only thing I haven't replaced it the ecu and the crank sensor please someone help my I am about to loose it with this car.
Old Mar 5, 2010 | 11:33 AM
darthroush's Avatar
darthroush
Section Moderator
Does the car crank over?
Old Mar 5, 2010 | 09:24 PM
bielskia's Avatar
bielskia
it will turn over but not crank it acts like its not getting a spark. which it is not also i already changed the cam sensor and coil
Old Mar 6, 2010 | 01:06 AM
darthroush's Avatar
darthroush
Section Moderator
I'm not sure I'm following. Probably just different uses of the words. What do you mean it will turn over, but not crank over?
Old Mar 6, 2010 | 06:41 PM
bielskia's Avatar
bielskia
Right it will turn over and all but not start. I am not getting a spark to my coils but I am getting power to my cam sensor please any ideas I am about to take it to the dealership.
Old Mar 7, 2010 | 02:01 PM
darthroush's Avatar
darthroush
Section Moderator
I'd start looking over the wiring. It may possibly be the PCM as well. Did you have any codes?
