Shifter/lights wire assembly help love of god help
So as it seems with 03 dodge neon sxt's i had my multi function switch **** the bed and melt all over the damn place.. this is at least the info that ive seen other places. SO anyways got the multi function switch.. had to get a new wiring harness.... somethings not right tho.. something isent where it should be. I've searched around and can't seem to find the schematic for it. Or a picture would be perfect ha! So any ideas where to find that damn wiring assembly map or whatever you want to call it? Any help would be nice driving with no lights is not really working out too well. Thanks much
MULTI-FUNCTION SWITCH - GRAY 20 WAYCAVCIRCUITFUNCTION1L50 18WT/TN (EXCEPT EXPORT)BRAKE LAMP SWITCH OUTPUT /2L61 18LGLEFT TURN SIGNAL /2L61 18LG (EXPORT)LEFT TURN SIGNAL /3L6 20RD/WTFUSED IGNITION SWITCH OUTPUT (RUN-ACC) /4L63 18DG/RDLEFT TURN SIGNAL /4L63 18DG/RD (EXPORT)LEFT TURN SIGNAL /5L62 18BR/RDRIGHT TURN SIGNAL /5L62 18BR/RD (EXPORT)RIGHT TURN SIGNAL /6L60 18TNRIGHT TURN SIGNAL /6L60 18TN (EXPORT)RIGHT TURN SIGNAL /7Z3 20BK/ORGROUND /8E19 22RDPANEL LAMPS DIMMER SIGNAL /9L7 18BK/YLHEADLAMP SWITCH OUTPUT /10-- /11A15 18WTFUSED B(+) /12L38 16BR/WT (EXPORT)REAR FOG LAMP FEED /12L38 16BR/WT (EXPORT)REAR FOG LAMP FEED /13L4 14VT/WT (EXCEPT EXPORT)DIMMER SWITCH LOW BEAM OUTPUT /13F61 16WT/OR (EXPORT)FUSED B(+) /14F39 14PK/LG (EXCEPT EXPORT)FRONT FOG LAMP SWITCH OUTPUT /14L39 16LB (EXPORT)FRONT FOG LAMP SWITCH OUTPUT /14L39 16LB (EXPORT)FRONT FOG LAMP SWITCH OUTPUT /15-- /16L4 12VT/WTDIMMER SWITCH LOW BEAM OUTPUT /17L33 14LG/BRDIMMER SWITCH HIGH BEAM OUTPUT /18F3 12LB/ORFUSED B(+) /19F3 12LB/ORFUSED B(+) /20F33 18PK/RDFUSED B(+) /
