Magnum Head for Neon?
Old Mar 17, 2010 | 05:37 AM
05 Neon's Avatar
05 Neon
Default Magnum Head for Neon?
I see this mentioned frequently, but with little or no explanation. Someone want to clue me in? Is this a V8 head that magicly fits on a 4?
Old Mar 17, 2010 | 05:52 PM
Ghost Neon 2's Avatar
Ghost Neon 2
The 2001-2005 neon r/t has the aforementioned Magnum cylinder head. This cylinder head is different from every other neon sohc cylinder head. This cylinder head can be identified by "R/T" casting nearest the coolant neck and the (larger than stock) large exhaust ports. The 2G r/t also has a multi port intake manifold , more aggressive cam shaft grind, and a tubular exhaust manifold to take advantage of the huge exhaust ports on the cylinder head. HTH
Old Mar 19, 2010 | 07:12 PM
AlaskaNeon01's Avatar
AlaskaNeon01
aaaand that bolts on to the motor easily ?
Old Mar 25, 2010 | 01:24 PM
2002ACRNEON's Avatar
2002ACRNEON
The limited production ACR's (2001-2002) also used the "magnum" head's, header, manifold tuning valve, hotter cam, etc, etc..
I had both an '01 ACR and an '02 ACR. They were so fun they were both totalled.
Old Mar 26, 2010 | 04:25 AM
05 Neon's Avatar
05 Neon
So, can this "Magum" head be bolted to any other (read- 2005 2L) engine? Or do I need to find the whole engine? Then will it mate to my Xmission, or do I also need to find one in the same model year?
