radiator replacment help.
Old Mar 20, 2010 | 03:26 PM
me0418840987's Avatar
me0418840987
Default radiator replacment help.
Has anyone replaced a radiator in a 2nd gen neon? Is there an easy way to do it without removing the A/C condensor? I am trying to replace it now, but the condensor is really tight to the rad and I don't want to damage the new one when it goes back in. I got the old one out, But it hit on the brackets for the condensor, and put a pinhole in it. Any tips would be appreciated. Thanks.
Old Mar 20, 2010 | 08:32 PM
bullitt91's Avatar
bullitt91
ive done it....i never want to again.... its a pain in the a$$ w/o taking out the ac. i bent the out of the way... very carefully. there also 2 more bolts on the bottom of the rad. you get to them through the lower grille in the front. i took out the fans, airbox, throttle body, everything i could to give me more room.
Old Mar 20, 2010 | 08:35 PM
bullitt91's Avatar
bullitt91
brackets* sorry
Old Mar 27, 2010 | 10:07 PM
me0418840987
Yes, thats exactly my story, just wondering if there were any tricks to it.
Old Mar 28, 2010 | 02:47 PM
mjs182004's Avatar
mjs182004
Sorry I can't help you with this. Can I ask what went wrong with you rad.? Only reason I ask is because there might be something else that will go wrong in the near future.
Old Mar 29, 2010 | 11:41 PM
bullitt91's Avatar
bullitt91
such as a transmission... like mine...
Old Mar 30, 2010 | 12:03 AM
NHARINTON's Avatar
NHARINTON
essayist way I found is to take all nuts, screws, hoses and electrical connections off, disconnect the motor mounts on passengers side (two bolts) and then pull the electric fan out, it takes some convincing, and then the radiator. It makes it easier if you pull the whole intake off too, if you really want to make it easy take the intake manifold off. Leave the AC condenser in. Then do the reverse. Took me about 2 hours too pull 2 radiators and install the "new" one (less cracked)........ Got to do it again in a few days with a new one though.
Just be nice with the radiator, its 1/2 plastic.
Old Mar 30, 2010 | 02:43 PM
mjs182004's Avatar
mjs182004
Like yours, mine and pretty much all of them.
Old Apr 3, 2010 | 12:20 AM
me0418840987
Only thing wrong is either I nicked the rad when I put it in, or it was junk from the supplier. I needed a new one because the original was wrecked when the car was totaled.
Old Apr 4, 2010 | 10:44 PM
bullitt91's Avatar
bullitt91
ohhh man. thats horrible. its bad enough doing it once but twice? ouch sorry pal
