peice of crap
It worked in my car and I haven't had the car fail to start since.
If its not cranking. your computer may need reset/flashed. You replaced all that stuff so at some point it could have tripped your security system. I have messed alot with the security keys and the anti-theft system on the neons. WHen you go to crank it dose the red security light on the gauge cluster blink or stay solid lit?
MOst likely its your key......
Try jumping it with the starter. if its your key or theft system it will run for a few seconds and die.
