RTV curing time before trans fluid fill???
Old Apr 3, 2010 | 12:15 PM
Olddaddrivindaughterscar's Avatar
Default RTV curing time before trans fluid fill???
I just finished installing the trans pan with the recommended RTV sealant and the directions on the RTV tube say that it dries within one hour but that it is completely cured in 24 hours.
So I am wondering how soon I should add the trans fluid. Should I wait 24 hours? I left the trans drain overnight so that there wasn't any fluid left driping onto the mating surfaces and I torqued the bolts in three steps up to the recommended torque.
Any help would be appreciated.
Old Apr 3, 2010 | 12:41 PM
NHARINTON's Avatar
NHARINTON
I let mine sit for about 3-4 hours. No leaks.
Old Apr 3, 2010 | 01:02 PM
deranged's Avatar
deranged
3-4 hours should be fine. If you don't need to drive it immediately then I'd let it cure over night.
Old Apr 4, 2010 | 06:33 PM
Default Overnight it was
It so happened that I did not have to drive the car so I let it cure overnight. I filled it this afternoon, checked for leaks, drove it some, checked for leaks again, added some fluid, drove it some more, checked for leaks...
Anyway-it went well and I am happy to report -NO LEAKS ! I sure did not want to pull the pan and have to reseal it again.
Thanks for the responses.
Old Apr 4, 2010 | 08:10 PM
darthroush's Avatar
darthroush
Section Moderator
The dealership told me that once the pan was on and tightened properly, you could fill it up and be on your way. It's good to know that they can know what they are talking about at times.
