Studder or hesitation from a stop
Old May 27, 2010 | 08:46 PM
White2000Neon's Avatar
White2000Neon
Default Studder or hesitation from a stop
I have a 2000 Neon automatic with 82k miles that after the engine has warmed up will studder or hesitate when starting from a stop. It is less likely to do it when I am not running accessories (e.g headlights, fan or a/c). If I am running the a/c I have to switch it off to take off.
The studder or hesitation is causing me to feather the accelerator from a stop. Once the RPMs get above 3000 the car doesn't seem to have a problem.
I have replaced the plugs and wires. Any suggestions what I should look at next?
Old May 28, 2010 | 01:16 AM
Moparkyle's Avatar
Moparkyle
Sounds like a possible tensioner or bad belt.
Old Jun 1, 2010 | 10:46 AM
opie9797's Avatar
opie9797
try the idle air control valve after some time it will stick i got a 2000 es with 84000 on it and nothing yet but i drive it for a while and when stopped my idle goes to 400 rpm and i can feel it shake a little then it catches itself back up to normal 850-900 hope this helps
