Need a 2nd key.
Old Jul 1, 2010 | 04:14 PM
  #41
darthroush's Avatar
darthroush
Section Moderator
I *wish* an Ace Hardware store around here could pull that off. Maybe I'll call down to the city...
Old Jul 1, 2010 | 06:10 PM
  #42
AnthemBassMan's Avatar
AnthemBassMan
-Seems like we have quite a lot here in Ohio. I live in the country, but a 30 minute drive in just about any direction and I can be at no less than 7 different guitar shops. Also the same amount of driving time will put me at 9 different golf courses. One course club house is exactly 1.5 miles from my front door.
L8R,
Matt
Old Oct 3, 2011 | 04:26 AM
  #43
MJSchutt's Avatar
MJSchutt
if you go online to ebay, amazon, etc... get a blank transponder key that works with your car. have it cut at you local hardware store. Then you need to get your hands on a DRB III scan tool (Computer needed to connect to your car) a lot of Auto parts stores will loan or rent them, or you can pay the 1-3 Grand to buy one. after that you will need your cars 4 digit pin which is based off the VIN # after that, follow these instructions
STANDARD PROCEDURE - TRANSPONDER PROGRAMMING
USING A DRB III® SCAN TOOL
All Sentry Keys included with the vehicle are pre-programmed to work with the Sentry Key Immobilizer System (SKIS) when it is shipped from the factory. The Sentry Key Immobilizer Module (SKIM) can be programmed to recognize up to a total of eight Sentry Keys. When programming a blank Sentry Key transponder, the key must first be cut to match the ignition lock cylinder of the vehicle for which it will be used. The vehicle's four digit PIN code will be required to complete this task since you will need it to enter the Secured Access Mode in the SKIM. The following steps must be completed using a DRB III® scan tool:
Insert the blank key into the ignition and turn it to the RUN position.
Using a DRB III® scan tool, select "Theft Alarm," "SKIM," "Miscellaneous," and then "Program Ignition Key."
Enter the four digit PIN code using the DRB III® scan tool. When programming is completed, the SKIM will exit Secured Access Mode and the DRB III® scan tool will display the results of your attempt to program the key. One of five distinct results may be displayed. All five are listed below:
"Programming Successful" is displayed if the Sentry Key programming is successful.
"Learned Key in Ignition" is displayed if the key in the ignition has already been programmed into that vehicle's SKIM.
"Eight Keys Already Learned (At The Maximum) Programming Not Done" is displayed if eight keys have already been programmed into the SKIM. In this case, if a new key needs to be added due to a lost or defective key, the "Erase All Keys" command (which requires entering the Secured Access Mode) has to be performed. Following the "Erase All Keys" command, all keys that will be used to operate the vehicle MUST be reprogrammed to the SKIM.
"Programming Not Attempted" is displayed after an "Erase All Keys" function is executed.
"Programming Key Failed" is displayed if further diagnosis is required.
To learn additional keys, turn the ignition OFF, remove the learned key, insert the next new blank key, and repeat the steps from the beginning.
found these instructions HERE
Old Oct 3, 2011 | 04:30 AM
  #44
MJSchutt's Avatar
MJSchutt
if you have two keys already it gets lots easier.
“CUSTOMER LEARN” MODE
This feature is only available on domestic vehicles or those which have a U.S. country code designator. This procedure requires access to at least two valid Sentry Keys. If two valid Sentry Keys are not available, Sentry Key programming will require the use of a DRB III® scan tool.
The steps required to program Sentry Keys with two valid Sentry Keys follows:
Obtain the blank Sentry Key(s) that need to be programmed. Cut the keys to match the ignition lock cylinder mechanical key codes.
Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the ON position.
After the ignition switch has been in the ON position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the OFF position. Replace the first valid Sentry Key in the ignition lock cylinder with the second valid Sentry Key and turn the ignition switch back to the ON position. The second valid Sentry Key must be inserted, and the ignition key to the ON position, within 15 seconds of removing the first valid Sentry key.
About ten seconds after the completion of Step 3, the indicator light will start to flash and a single audible chime tone will sound to indicate that the system has entered the "Customer Learn" programming mode.
Within sixty seconds of entering the "Customer Learn" programming mode, turn the ignition switch to the OFF position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the ON position.
About ten seconds after the completion of Step 5, a single audible chime tone will sound and the indicator light will stop flashing and stay on solid for three seconds and then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the "Customer Learn" programming mode and the vehicle may be started using the newly programmed Sentry Key.
These steps must be completed in their entirety for each additional Sentry Key to be programmed. If any of the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the "Customer Learn" programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the "Customer Learn" programming mode if:
It sees a non-blank Sentry Key when it should see a blank.
If it has already programmed eight ( valid Sentry Keys.
If the ignition switch is turned to the OFF position for more than about fifty (50) seconds.
NOTE: If you attempt to start the vehicle while in “Customer Learn” mode (LED flashing), the vehicle will behave as though an invalid key is being used (i.e. the engine will stall after two (2) seconds of running). No faults will be logged.
NOTE: Once a Sentry Key has been programmed to a particular vehicle, it cannot be used on any other vehicle.
Found HERE
Same as above post
Old Oct 3, 2011 | 04:41 AM
  #45
MJSchutt's Avatar
MJSchutt
I've read from a lot of places that if you call your local dodge service dept. and give them the last nine digits of your VIN, they will give you your 4 digit PIN
Old Oct 3, 2011 | 04:15 PM
  #46
darthroush's Avatar
darthroush
Section Moderator
What "a lot of parts stores" are you talking about? By that, I mean companies. I've never heard of or been to a parts store having dealer-specific tools that they loan out, especially ones in the price range of a DRBIII. Most of them don't know what some common car tools are, like a ball joint press.
Old Oct 5, 2011 | 11:28 PM
  #47
MJSchutt's Avatar
MJSchutt
I just went by O'Reilly's auto parts a couple days ago and they told me they used to rent them out, but someone stole theirs. so now they only loan them so long as you stay in the parking lot. I imagine other places like NAPA would do the same thing. I just ordered two RAM head logo transponder keys off ebay a couple days ago, they should be here Thursday; I dropped by my local dodge dealership, showed proof of ownership and my license today and they gave me the 4 digit PIN for my computer. This weekend I'll bring the keys to the hardware store, have them cut, go to the auto parts store for the DRB III, and in 10 minutes or so I should be all set with 3 new keys.
Old Oct 5, 2011 | 11:32 PM
  #48
MJSchutt's Avatar
MJSchutt
*UPDATE*
I called the dodge retail parts dept.
they told me it's Illegal to give out the 4 digit PIN over the phone. (for what I realized were pretty obvious reasons with car theft and all.)
you must be there in person, with proof of ownership, and ID before they will give it to you.
Old Oct 6, 2011 | 12:50 AM
  #49
darthroush's Avatar
darthroush
Section Moderator
O'Reilly's is specifically who I was thinking of who doesn't know what some more basic tools are, lol. That's got to be totally dependent on who runs/owns each store. I wouldn't buy any means assume that is normal for all brand store "X's" to have the same tools; especially one like the DRBIII. There is only one shop where I live that I know has a DRBIII.
That would be nice to be able to use on for free real quick though!
Old Oct 6, 2011 | 03:08 AM
  #50
MJSchutt's Avatar
MJSchutt
Yea, I was pretty pleased about it too. I normally wouldn't touch O'Reilly's with a ten foot pole, seeing as they have screwed up my orders so many damn times. But in this case I just needed some "Stone White" touch up paint of the shelf and they were close by, so i thought "while im in here...".
Normally, NAPA is the way to go. Back to topic though, I have a couple buddies that i could have gotten one from so I wasn't stuck, just found a convenient way.
