need help with obd2 code..
Old Jun 6, 2010 | 08:05 PM
turboevolution01's Avatar
turboevolution01
Default need help with obd2 code..
whats up guys? i just pulled a engine code out of my 04 neon sxt..the code is p2097 im having trouble finding what the code is for if anyone can help i would appreciate it..thanks..
Old Jun 7, 2010 | 02:34 AM
darthroush's Avatar
darthroush
Section Moderator
P2097-DOWN STREAM FUEL SYSTEM 1/2 RICH
When Monitored:
With the engine running in closed loop mode, the ambient/battery temperature above (-7°C)20°F and altitude below 8500 ft.
Set Condition:
If the PCM adds downstream short term compensation to long term adaptive and a certain percentage is exceeded for two trips, a freeze frame is stored, the MIL illuminates and a trouble code is stored.
Possible Causes:
  • GOOD TRIP EQUAL TO ZERO
  • EXHAUST LEAK
  • ENGINE MECHANICAL PROBLEM
  • O2 SENSOR
  • O2 SIGNAL CIRCUIT
  • O2 RETURN CIRCUIT
  • FUEL CONTAMINATION
