Lights
Old May 14, 2005 | 10:57 AM
NeonSxT03's Avatar
NeonSxT03
Default Lights
I just bought new tail lights off of ebay and since the didnt come with instructions I was wondering if the install would be difficult. And I was also looking to buy new smoked side markers and wanted to know how difficult those are to replace.
Thanks in advance
Old May 14, 2005 | 03:52 PM
AirWolf's Avatar
AirWolf
Default RE: Lights
I just put on the new TYC for the 03-05 taillights on yesterday so easy and the smoked sides are not to hard either. What kind of tails did you get.
Old May 15, 2005 | 02:14 AM
NeonSxT03's Avatar
NeonSxT03
Default RE: Lights
I got carbon fiber euro altezzas
Old May 15, 2005 | 02:30 AM
GroundControl's Avatar
GroundControl
Default RE: Lights
Just pop the trunk. pull the lil plugs out that hold the carpet in around the back tail light. after u pull the carpet away then u will see 3 plastic caps that screw down to hold the light in. first twist the light bulbs and take them out. after that just unscrew the 3 plastic caps. Do that for each side and u should be fine.
Old May 16, 2005 | 12:42 AM
NeonSxT03's Avatar
NeonSxT03
Default RE: Lights
I put them on and it was a lot easier than I thought thanks for the help. There is one minor problem though, there is a gap between the top of the lights and the body of the car and I was wondering if there is something I could put in there so water doesnt get into it and ruin the lights.
Thanks again
Jeremy
Old May 16, 2005 | 12:53 AM
AirWolf's Avatar
AirWolf
Default RE: Lights
Thin kthey jus thave to be tightened or lined up a little more same happened to me when I screwed them more they straightened up.
