Is this safe?
Old Sep 2, 2010 | 03:47 AM
seaneon00's Avatar
seaneon00
talk about dramatic...I got my fan working and it only took about ten hours...but if I ever need to do it again (on another of the exact same car) I could do it in about 20 minutes.
Old Sep 2, 2010 | 06:33 AM
sapporo's Avatar
sapporo
geez, you shoulda taking electricity class in HS shop. I hope you used some type of circuit protection device (aka fuse) on the power circuit. also you'll probably get a MIL for fan relay control. but black tape will fix that problem over the light so you don't see it on all the time.
Old Sep 2, 2010 | 01:38 PM
seaneon00's Avatar
seaneon00
I got a check engine light and a P___ code that was a relay code, but I put the old relay back in the now empty slot and it went away. (which means the old one was fine, but I knew that)
I just made an omelet. It wasn't great. I guess I should have taken cooking in high school too, but at least I tried I guess...and the next one will be better.
