Suspension for my 04 sxt!
Lookin for a better suspension for my sxt .Want to lower her a little a mean look is what Im going for would srt stock springs work pretty good for my sxt and would a front srt sway bar do anything.Want more srt stuff on my sxt.
if you want to lower srt-4 oem wont help, just give you a srt-4 feeling stock. Bets bet, after market shocks from tokiko or kyb, coilovers from aropseed and rear sway bar from progress, Cost you about maybe $450 to $500, for a nice and adjustable and stiff ride and great looks.
i have eibach springs on my 02 sxt, and does it look nice now. i hated how high the car sat. i installed these with just 700 miles on my car. it was my first upgrade. i used the stock struts and it dropped about 2" f/r. i recommend a set of good struts if budget allows. i'm upgrading to kyb's in about a month. also, if you plan to upgrade the front sway bar, you can use a srt-4 front bar. it's 24mm vs 20mm of the stock sxt. just beware that the energy suspension poly bushings that mount it to the frame don't bolt up without installing a plate under them to hold the bushing in place. i just found that out today. also, take your time removing the front bar mounting bolts as they have a tendency to rust in place. both snapped on my car. the rear swaybar from an srt is 17mm. that's better than 0mm from stock. just install those upgraded struts with your lowering springs and install that rear bar with ease. remember to use poly end links to complete the install. have fun!
