Crankshaft sensor and Camshaft sensor code problems
Old Sep 25, 2010 | 10:04 AM
mppittman's Avatar
mppittman
ya i have done timing jobs before but never on a neon but i was just mainly wanting know the easiest way to get to it but my question was answered.Now i would be better off on just buying the timing belt kit with everything right...bc isn't it a rule of thumb to change the water pump when u do one.
Old Sep 25, 2010 | 02:02 PM
darthroush's Avatar
darthroush
Section Moderator
Originally Posted by sapporo
after I do any timing systems, I always hand turn the crank 2 full revolutions to make sure everything lines up perfect before I button up the job or attempt to start.
That's a very good tip! People don't do this, and then put everything back together and are off one tooth.
The timing belt, water pump and tensioner should all be replaced together, yes. I recommended the other ones because they wear, and since you have to remove them to get to the timing belt, you may as well save yourself the trouble of taking it all apart again later. For example, the motor mount is just about the last thing, if not the last, you remove before you have access to the timing cover.
Old Sep 26, 2010 | 09:40 AM
mppittman's Avatar
mppittman
Ya im going to do it right bc it has 172,000.But does anybody have a clue on how much a water pump will run and a tensioner. Thanks
Old Sep 26, 2010 | 10:26 PM
darthroush's Avatar
darthroush
Section Moderator
From my first reply in this thread...
Originally Posted by darthroush
You can get the timing kit on Amazon for ~$88 shipped. The kit comes with the first three.
The "first three" referring to the timing belt, timing belt tensioner and the water pump.
Old Sep 29, 2010 | 09:21 PM
mppittman's Avatar
mppittman
ok i checked my timing marks and they are lined up and the belt is tight so i dont know where to go now.Dealership said all the sensors are good and told me to do the timing belt but dosent make sense if the marks are lined up and the belt is tight. Im going to try the pcm now.
Old Sep 30, 2010 | 06:40 AM
sapporo's Avatar
sapporo
stupid question, did you bend any valves? do you have a DOHC engine? could have on cam 180° out I've seen people do that before
Old Sep 30, 2010 | 11:04 AM
mppittman's Avatar
mppittman
no its single over head and it drives fine untill it hits 2300 rpm and stumbles a lot kinda like the rev limiter.
Old Oct 1, 2010 | 06:18 AM
sapporo's Avatar
sapporo
what is the fuel pressure at rpm comes up?
Old Oct 2, 2010 | 10:23 AM
mppittman's Avatar
mppittman
didnt really check it but fuel preassure isnt going to be it bc only the cam and crank code set and since the cam and crank sensors arnt working right the engine is just dumping fuel into the engine bc it dosent know exactly how much to give it since the can and crank sensors are telling the computer what it wants
