I need help Fast, Neon Wont Start.
Old Nov 4, 2010 | 06:05 PM
Daniev2221's Avatar
Daniev2221
ok i did a compression test i am unsure if the compressions suppose to slowly drop because 3 of them went high then went down slowly, 1 on the other hand held no compression at all
Old Nov 4, 2010 | 06:24 PM
darthroush's Avatar
darthroush
Section Moderator
Sounds like a bad compression testing gauge, for starters. The gauge will hold the highest reading until you release the built-up pressure. Well, it's supposed to...
You already know there is a problem. A compression test isn't going to tell you anything new. Something broke internally and the engine will have to come apart to fix it.
Last edited by darthroush; Nov 4, 2010 at 06:29 PM. Reason: Grammar issues today...
Old Nov 4, 2010 | 09:31 PM
hemi4spd's Avatar
hemi4spd
it will only tell you what cylinders you need worry about
the gague should hold the maximum pressure till u release it
the cylinder with no pressure is the one with the bent valve(s)
start pulling off the head
Old Nov 4, 2010 | 10:15 PM
darthroush's Avatar
darthroush
Section Moderator
If you replace the whole head instead of performing valve jobs, it doesn't matter which one it is. I suppose it would help if the chosen method of repair was said.
Old Nov 6, 2010 | 03:37 AM
Daniev2221's Avatar
Daniev2221
alight i did a compression test an 3 held there compression but not for long it slowly droped an one didnt hold at all
Old Nov 6, 2010 | 03:30 PM
darthroush's Avatar
darthroush
Section Moderator
That's what I was saying. They are not supposed to drop. Your tester is worn/broken. It doesn't matter at this point. The head still has to come off no matter what cylinder has no compression. Take the head off and get going!
Old Nov 6, 2010 | 05:15 PM
Daniev2221's Avatar
Daniev2221
alright i got the heads off an 2 sets of valves are open the others are closed
Old Nov 10, 2010 | 11:49 AM
martiniac's Avatar
martiniac
That's pretty normal as the pistons work in pairs. Try turning the cam to see what happens....
While you have the head off, take it to a machine shop for resurfacing and a check-up. Better safe than sorry.
Old Nov 11, 2010 | 01:46 PM
hemi4spd's Avatar
hemi4spd
remove the cams
then all valves "should" be closed
turn head upside down and fill combustion chambers with varsol
whatever combustion chamber doesnt hold liquid has the bent valves
thats if the gap between valve and seat isnt obvious
or you could just look at the pistions they should tell you where they hit
Old Nov 19, 2010 | 01:04 PM
hemi4spd's Avatar
hemi4spd
prices here are much different
whole engines are from about 400 and up
heads are about 200 and up
valves about 15 bucks each and your only going to need a couple
and the spring compressor can be rented for a few bucks.
I wish I knew a place to get heads at 30 dollars, its almost worth buying them to strip them down for aluminum scrap at that price
who knows what type of condition the junkyard head is in?
