04 SXT Head Replacement
Old Jan 23, 2011 | 03:27 PM
silentdub's Avatar
silentdub
Default 04 SXT Head Replacement
04 2.0L non turbo, I just replaced the head gastket and bolted the head back on and yet, cylinder 4 still leaks. It won't hold any air.
I feel the air coming up through the other holes around #4 like the oil holes.
The first 3 cylinders are fine, I don't see any cracks on #4, the valves look to be seated fully, not sure what is going on.
The piston looks fine, no damage on the cylinder walls.
I see a ton of used heads for sale, has anyone had good luck with used head or should I just go new/rebuilt?
Can someone also confirm the torque is 50ft lbs?
Thanks!
Old Jan 23, 2011 | 03:41 PM
silentdub's Avatar
silentdub
I just cleaned up the valves with a wirewheel and I don't see any cracks, so not I am scratching my own head!
