very cold weather, back engine noise
Old Feb 1, 2011 | 06:04 PM
possible neon owner's Avatar
possible neon owner
Default very cold weather, back engine noise
today i started my 2003 neon, and it is -10 degrees f. here, when i first started it the engine made all sorts of wierd noises, now it hasa ticking / knocking noise coming from it, it does it till the engine warms up, any thoughts?
Old Feb 1, 2011 | 06:15 PM
showsxt's Avatar
showsxt
Neons dont like cold weather mine sure doesnt. Mine does the same in very cold weather.
Old Feb 1, 2011 | 06:31 PM
darthroush's Avatar
darthroush
Section Moderator
What weight oil are you running?
Old Feb 1, 2011 | 07:06 PM
Moparkyle's Avatar
Moparkyle
Piston slap, as soon as it get's really cold most Neons do it. Don't be too concerned as long as it goes away within a minute or so.
Old Feb 2, 2011 | 12:09 AM
possible neon owner
ok i was just wandering, im running 10w-30 full synthetic
Old Feb 2, 2011 | 12:33 AM
possible neon owner
the really weierd noise goes away in under min, but the ticking/ knocking noise goes away after 5- 10 min of running, i let it warm up for about 20 min before i drive it
Old Feb 2, 2011 | 01:23 AM
Moparkyle's Avatar
Moparkyle
My car absolutely HATES cold starts. It makes about 4 different noises when it's started below like 10 degrees.
Old Feb 2, 2011 | 05:08 AM
darthroush's Avatar
darthroush
Section Moderator
Go with a 5W20. It'll be better for the cold weather.
Old Feb 2, 2011 | 01:16 PM
possible neon owner
yah it is hard to keep changing the oil based on the weather where i live, one day its 65 degrees and the next morning its -10, then the next day its 55 degrees, it crazy weather, with all my other cars i usually run 10w-30 year round, plus my car is stored inside a heated garage
Old Feb 2, 2011 | 11:56 PM
darthroush's Avatar
darthroush
Section Moderator
5W20 is fine year 'round.
