02 Neon ES questions
Hey and Hello, I am JackJ. I usually peruse the 2nd gen ram pages but I am going to be fixing a friends car this weekend or next and have a few questions.
First off I was initially under the impression that the car was an 05 and bought a oil pan gaskete for such only to fins out that the car is in fact an 02, will it work or did it change, I did however realize it was a standard so I am 1 for 1 so far.
Second, in the process of him driving his car onto a curb and cracking the pan he also sheared the lower engine mount bolt and the only one my FLAPS has is a generic grade 8 bolt, that I put on order if some one could possibly shoot me the part number for the bolt so i can order the right one if this one does not work.
Third, does anyone have access to or can provide a link to where I can DL a copy of the FSM for this car or one that would work.
Thank you in advance for you time and replies however helpful they may or may not be.
I'd think a grade 8 bolt would be fine and then some for the mount. I've got a grade 5 as a replacement on the ball joint. If you really want an OEM bolt, just go to the dealer. They should be able to find it with ease.
