Megasquirt
Old Feb 24, 2011 | 11:17 AM
bmc2004's Avatar
bmc2004
Default Megasquirt
i've read up on it and have some questions. What is the difference between a megasquirt and a chip, does it really increase horsepower and by how much, and does it really work. also has anyone ever actually used one and what was it like?
Old Feb 24, 2011 | 12:38 PM
darthroush's Avatar
darthroush
Section Moderator
From the Megasquirt FAQ sticky:
1. What is MegaSquirt?
MS is a full standalone fuel and spark controller. MS can completely replace your stock PCM, however you will need additional relays and wiring etc. to power all of your accessories. For this reason most people used the stock PCM to power all the accessories and sensors, while MS takes over engine control.
The difference is Megasquirt will allow you to actually tune your engine to gain more power, whereas a chip says you will gain more power but actually don't.
Old Feb 24, 2011 | 07:53 PM
bmc2004's Avatar
bmc2004
Where can i get one of the megasquirts?
Old Feb 24, 2011 | 09:37 PM
darthroush's Avatar
darthroush
Section Moderator
That's in the FAQ too...read it. Lots of good info about it in there!
