2001 Neon non-functioning Air Conditioner
Old Apr 7, 2011 | 06:20 PM
PsychoDad5's Avatar
PsychoDad5
Default 2001 Neon non-functioning Air Conditioner
My mother took her 2001 Neon to get her air conditioning repaired. She was told it was the computer but as I look at the schematics is seems the only part that routes throuth the computer is compresser pressure and fan sensor. They want $250-$300 labor to remove and replace computer plus another $275 to rebuild the computer.
Is this normal or does the computer just tell you when the pressure is too low or high?
I do beleive she is being taken advantage of, the final repair has not been authorized yet so a quick answer would be fantastic.
Thanks,
Clayton
Old Apr 7, 2011 | 07:00 PM
darthroush's Avatar
darthroush
Section Moderator
Does the A/C work now?
Old Apr 7, 2011 | 07:57 PM
PsychoDad5's Avatar
PsychoDad5
No, repairs have not been authorized yet.
Old Apr 7, 2011 | 08:30 PM
darthroush's Avatar
darthroush
Section Moderator
I wouldn't authorize that either. $300 to remove the computer? It takes about 5 minutes to get to. Remove the air box and there it is. Have they checked/tested the relay(s)?
Old Jul 1, 2011 | 12:53 PM
shootergdv's Avatar
shootergdv
Follow up ? I have a similar problem but worse. Paid $660 for new AC "kit" and still have very minimal AC, been told it is the computer now. Great diagnostics, huh ?(that was $25 of the bill !) See that on-line you can get a PCM for $225 prgrammed to your VIN, guess I'll have to try it. Would've been better served using these $$ and car as trade.
Old Jul 1, 2011 | 04:24 PM
Matix151's Avatar
Matix151
can u verify if they atleast hooked up to guages and read the pressures or evacuated the system to see how much of a charge was in the system?
