megasquirt question
Old Apr 22, 2011 | 11:51 PM
krain88's Avatar
krain88
Default megasquirt question
ok so im looking into getting ms for my 05 sxt and im just really confused.....i see the complete kits online but do they come with the harnesses to hook them up to your car or do you have to get them seperately? ive tried calling them but i cant get any help lol so can someone please help me?
Old Apr 23, 2011 | 02:50 AM
buddhaman's Avatar
buddhaman
Originally Posted by 03neonRT
1. What is MegaSquirt?
Option B: Prebuilt unit (recommend rs-autosport.com)
- When ordering the ECU from rs-autosport specify the follow options:
Configuration: Neon/420A
Fan control output: No (assuming stock ECM still controlls radiator fan)
Firmware: Latest stable release of MSnS-E
Map sensor: Your preference
Tachometer signal output: No (assuming no additional tach signal is needed. i.e. you're not adding any other hardware that requires a tach signal).
Upgrade to MegaSquirt II: Standard MS-1 controller
You will still need:
- GM IAT and CLT sensors
- Wiring Harness
- Stimulator (optional)
5. Firmware
The latest version of MSnS-E firmware can be downloaded here: http://megasquirt.sf.net/extra/ by clicking "download latest". This link also cantains all the info about the features of the "Extra" code and info about the Neon Crank Decoder, as well as hardware modifications required to control the coilpack. (the site says for pre-NGC Neons only, but MS will work on NGC cars and read the NGC crank trigger wheel)
The NGC code can be downloaded here:
http://megasquirt.texasneons.org/029v_ngc3.zip
FAQ Created by "turbodudey"
still have to get a harness from what it's looking like.
Old Apr 23, 2011 | 02:56 AM
darthroush's Avatar
darthroush
Section Moderator
It comes with wire and you have to wire up the sensors and such. The FAQ has good info, but it is a bit dated as far as I know.
Old Apr 23, 2011 | 10:21 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
you will need the list stated above.
harness
ms2 ecu unit
gm air intake temp sensor
gm coolant temp sensor
i would also recommend a program called ve anylizer live, it will tune your car as u drive, if u plan on tuning the car yourself this is the way to go, tuning while driving is not easy.lol
symtech can hook you up with all the products you need. i would go with there wiring harness also as there harness has a much better harness than diyautotunes. if u are looking at asps website then you are looking at symtechs products as an fyi.
if you go to aspturbo.com you can click on the engine management link and look at options, you will want ms2 daughterboard, sensors both, and 12 foot harness. the six foot is not long enough, and it is easier to cut wire than add to it...
