#1 Sluggish Acceleration #2 Grinding from 2nd to 3rd
Old Apr 23, 2011 | 12:30 PM
schmakdaddy's Avatar
schmakdaddy
Cool #1 Sluggish Acceleration #2 Grinding from 2nd to 3rd
Okay couple of problems.
I have a 04 Neon SXT 5-spd, when I am accelerating it is a lot more sluggish than it was 6 months to a 1 yr ago. I have changed plugs (copper) and wires. Also, have run fuel injector cleaner through system twice.
Secondly, when I am shifting (clutch all the way to the floor) from 2nd to 3rd I get a grinding going into 3rd. I know 100% that the clutch is 100% pressed and I don't know if there is a way for me to adjust he hydraulic clutch. I doesn't look like if from my research.
Any ideas would be great.
Old Apr 23, 2011 | 03:45 PM
Moparkyle's Avatar
Moparkyle
If it only does it from 2nd to 3rd then you can usually rule out the clutch.
Sounds like the syncros, linkage, or maybe trans/engine mounts can all cause the same thing.
Mounts may also cause you engine to feel more "sluggish"
