p0344 code even after sensor replacement
hey guys my 05 sxt is in limp mode. when i do the "key dance" p0344 comes up. according to my searches its the camshaft sensor. well i replaced that with a new gasket and reset the code but it still comes up. after more searching i found that the crankshaft sensor might need to be replaced so i replaced that and still nothing. what else might be the cause of this?
You may also want to consider that you bought a sensor that was a dud. Aftermarket prox sensors are notorious for failing right out of the box. I had it happen to my 300M; I replaced the cam sensor, and a month later the new sensor failed. I took the "new" sensor back to the auto parts store and got a free replacement, and I never had a problem ever again. If I recall the sensor was made by BWD and I bought it at Advance Auto. Not saying this is your problem, but it is still a possibility you may want to keep in mind.
is there a write up around here? i couldn't really find anything but i did learn that the magnets are different sizes among the 2nd gen
*sigh*
yeah i got the same code at autozone and all the wiring seems fine.
i'll prolly do that if replacing the magnet fails
*sigh*
The very last possibility is that the timing belt is off a tooth or so.
Trending Topics
okay i got the magnet and put it in. i still have the code. i inspected the wiring from the camshaft position sensor and none of it is burned but the black plastic thing that was around them it brittle and mostly gone. I'm at my wits end.
how can i check the timing belt?
