hard shuttering
Old Apr 23, 2011 | 11:27 PM
krain88's Avatar
krain88
Default hard shuttering
Ok so I just replaced my motor mounts with the massive hard mounts and I also replace the powersteering pully and belt but now for some reason the car is "shuttering" really bad at idle but goes away after I hit the gas? I was looking and one of my radiator fans will not kick on but the other one is running? Aren't they supposed to run at the same time? Can someone please help me I'm also not shoot any trouble codes
Old Apr 24, 2011 | 06:06 AM
darthroush's Avatar
darthroush
Section Moderator
What do you mean shuttering at idle? Bad vibrations?
Old Apr 24, 2011 | 08:15 AM
krain88's Avatar
krain88
Yea really bad vibrations I mean I expected to feel a little with the hard mounts just not the amount that I'm feeling it feels like the car is going to fall apart
Old Apr 24, 2011 | 02:31 PM
Moparkyle's Avatar
Moparkyle
Did you align the mounts correctly?
Old Apr 24, 2011 | 03:05 PM
krain88's Avatar
krain88
Yea I assume their mounted correctly lol the hole lined up lol and I torqued them to 70lbs which is what they called for....but the bolt for the bottom mount when I was putting it on fit through the bolt channel on the mount but not the the threads on the bracket on the motor it was to big.....so I used the oem bolt and it was a tad smaller maybe a size or 2 but went through the mounting bracket whould that be part of the hard vibrations? Keep in mind the vibrations go away once the car gets close to 1000 rpms maybe 900 and stay away till the rpms drop below that mark
Old Apr 24, 2011 | 07:50 PM
Moparkyle's Avatar
Moparkyle
There is a special alignment procedure for one of the mounts, pretty sure Darth has all the details.
Old Apr 24, 2011 | 09:05 PM
krain88's Avatar
krain88
yea i didnt know that lol so what i did for now i just pulled the bottom mount off and put the stock mount back on even though it is broke. i swear it was vibrating so bad you could probably watch the car walk across the parking lot lol. now i didnt change the trans mount b/c i have no idea how to even get to it.
Old Apr 24, 2011 | 09:12 PM
Moparkyle's Avatar
Moparkyle
As far as I know the trans mounts are usually the ones that last the longest on these vehicles.
Old Apr 25, 2011 | 02:28 AM
darthroush's Avatar
darthroush
Section Moderator
Link in sig
Old Apr 25, 2011 | 07:40 AM
krain88's Avatar
krain88
what the heck is link in sig darth?
