00 neon no crank and injectors wont shut off
Old Apr 29, 2011 | 12:59 PM
camrossrs99's Avatar
camrossrs99
Default 00 neon no crank and injectors wont shut off
i have a 00 neon with a manual trans as soon as i turn the ignition on the injectors startpumping fuel even before i try and start the car with this problem i can not even attempt to try and crank it over. when i do try to start it nothing happens any help would be great thanks. timming belt was just replaced and head was just rebuilt and checked. also when i try and scan the car my scanner says can not communicate with car so i cant even get the codes
Old Apr 29, 2011 | 01:01 PM
buddhaman's Avatar
buddhaman
sound to me like your computer is pooched
Old Apr 29, 2011 | 01:46 PM
camrossrs99
Also the auto shutdown relay for gas keeps clicking too even when car is off
Old Apr 30, 2011 | 02:52 PM
Moparkyle's Avatar
Moparkyle
The ASD relay is what powers your ignition and fuel injectors, I would get yourself a wiring diagram. As for the communication there are usually 4 important terminals to check on your diagnostic connector, power, ground, and the 2 data pins, don't know which pins they are off the top of my head so I would get a diagram for those as well.
