04 neon cabin filter
Old May 4, 2011 | 12:55 PM
razvancaine's Avatar
razvancaine
Default 04 neon cabin filter
Hi everybody. I just got a neon sxt 04 and it's really smell bad inside especially when I turn on the vent. There is a filter should I replace? Thank you
Old May 4, 2011 | 05:54 PM
AnthemBassMan's Avatar
AnthemBassMan
-There isn't any cabin filter that I know of. One thing you could do is remove the blower motor and clean inside the housing as much as you can. Maybe get one of those dryer vent brushes to clean as far into the duct work as you can. Then while running the fan on high, lightly spay some Lysol spray into the air vents from the outside. Clean the a/c evaporator too. Also scrubbing the interior and cleaning the carpets will help...
L8R,
Matt
Last edited by AnthemBassMan; May 4, 2011 at 06:01 PM. Reason: Because I'm An Idiot!
Old May 5, 2011 | 12:04 AM
darthroush's Avatar
darthroush
Section Moderator
You can make a cabin filter, but other than that, you need to clean the above.
Old May 5, 2011 | 03:14 PM
razvancaine
To remove the blower motor a screwdriver will be enough or do I have to seal or to replace something ? It's located under the passenger side dash, right? If I'll make a filter should I position inside the blower ? Thank you guys and I'm glad that seems to be a solution.
Old May 5, 2011 | 06:07 PM
darthroush's Avatar
darthroush
Section Moderator
No, you start stuffing things in the blower motor and your car will catch on fire. You'd place it under the cowl in front of the air intake vent.
Old May 5, 2011 | 08:47 PM
AnthemBassMan
-Also your a/c condenser could have some funk on it. Try cleaning that too...
L8R,
Matt
Old May 10, 2011 | 12:48 PM
razvancaine
How can I get to the a/c evaporator ? where is it located
