afx pcm
Old May 20, 2011 | 10:24 PM
neonvic's Avatar
neonvic
Unhappy afx pcm
i have a afx pcm (street) that i got from howell ,the problem is the car does not start .my car 01 neon es, no sentry system.took the car to a dodge dealer to have the vin number programed to it. the dealer said that they could not communicate with the afx pcm and that it did not work that it was bad.ccalled gary at howell told me it was not possible for the afx pcm to be bad ,to try another dealer .so i hooked up a scanner to it and got 3 codes p1486,p406 and p306.my understanding was that since my car has no sentry system (key) it should start .so my question is ,does the vin number need to be programed in the afx pcm even though no sentry key.to much money paid for something that does not work please help
Old May 21, 2011 | 01:34 AM
darthroush's Avatar
darthroush
Section Moderator
Sounds about right. Did he send you the correct year(s) PCM?
Old May 21, 2011 | 11:50 PM
neonvic's Avatar
neonvic
i think i got the right year .i did not ask Gary about the year.i did try another dealer but they will not do it because its a performance pcm.on tuesday i will go to a mexican dodge dealer and see if they can program the vin number since mexico does not have strict emission laws like california and see what happens
Old May 22, 2011 | 01:42 AM
darthroush's Avatar
darthroush
Section Moderator
You could also ask a local shop that has access to the DRBIII tool. I ask about the year because 2000-2002 is different than 2003-2005.
