Installing clear corners
Old Jul 9, 2005 | 07:52 PM
opyr8yr's Avatar
opyr8yr
Default Installing clear corners
Anyone know how to get at em? Do you need to remove the headlight assembly? Can't seem to get to the back of the side markers from the bottom..
Old Jul 10, 2005 | 01:07 AM
bb_stacker88's Avatar
bb_stacker88
Default RE: Installing clear corners
You should be able to pop them out through the fender if you remove the splash guard. I have not tried this so let me know if it works.
Old Jul 11, 2005 | 10:10 PM
01ACR's Avatar
01ACR
Wut year is yours? Mines an 01, and the manual says to remove the headlight assembly. So thats what I did. makes it way easier to get at. If yours is 03 or newer it could be different though. You should be able to look in your owners manual under the section about general care, and then in light bulb replacements. er somethin like that. It should be in there. Good Luck, and keep us posted on how it works out!
Old Jul 14, 2005 | 12:13 AM
hokiefan104's Avatar
hokiefan104
ORIGINAL: bb_stacker88
that's what the owner's manual for my '04 says to do. might be different for the '01 though.
