HELP! Electrical Issues
Recently i bought a new JVC deck to throw in my neon. I wired it in, and it ran fine for about a month. Recently, it started telling me there was a "miswiring" and to check the wiring. I did, and even re-wired the entire set of wires. Accidentally, i must have bumped two wires together, and my fuse light came on directly afterwards, but no fuses were blown. Now i have no power locks or dome light, and even the stock stereo no longer fires up. Also, the gauges go all funky when i first turn the key, then return to normal. I checked all the connections, and everything still has power running through it, but nothing is working. HELP?!
you have a blown fuse , there are 2 locations for fuses , the fuse center in the left hand side of the dash and one under the hood by the battery. look on the plastic cover and find the fuse that runs the things that dont work , there may be 2 blown. none the less its a fuse , had the same thing happen to me.
