2002 engine in a 2004 car?
Old Jun 26, 2011 | 01:30 PM
enelyam's Avatar
enelyam
Ok my friend, now i have issues. The wiring manual and the wiring colors in my car dont match. For example the 3 wires on my camshaft sensor its orange in the corner, black and light green stripe in the middle and brown and yellow stripe in the other corner. Where the diagram shows orange, black and light brown and tangerie and yellow. So now what i do need is to know how is the pin configuration for the sensors then since im not going to be able to use the exact color coding to try to fix that. So what is pin number 1, 2, 3 then?
Old Jun 26, 2011 | 04:55 PM
enelyam's Avatar
enelyam
Nevermind, the smartarch mechanic had the crankshaft plug in the radiator fan and the radiator fan plug in the crankshaft sensor... Wow, things happens sometimes but this was wayyyyyy too much lol........ Thank god im good at reading schematics!!
Old Jun 28, 2011 | 09:42 PM
enelyam's Avatar
enelyam
Well, problem solved! Bought another engine(2005) with less than 30k miles and everything is working perfect. There was no way i could use that 2000\2002 engine with the stock 2004 PCM. The crank shaft signal is way too different. So lesson learned the hard way. Admin please mark this thread as solved
Old Jun 29, 2011 | 02:16 AM
darthroush's Avatar
darthroush
Section Moderator
Solved!
Old Jun 29, 2011 | 06:28 AM
enelyam's Avatar
enelyam
Just in case someone is wondering why, i will try to explain it as simple as possible. 2000\2002 sensors use 8 volts instead of the 5 volts used by the 2003\2005 sensors. But even if you manage to regulate the voltage and get it up to 8 volts you will have a different signal sent to the PCM. Which gives a compatibility issue between those 2 engines, huge one in fact. Hope my bad experience helps people who may fall into the same trap and may ask themselves if this can be done. In my honest opinion its not worth even to try it.
Old Jun 29, 2011 | 02:59 PM
darthroush's Avatar
darthroush
Section Moderator
Thank you for sharing the experience though, to help others in the future that may wonder about this very same thing!
Old Jun 24, 2012 | 12:32 PM
jlcress's Avatar
jlcress
i have been told to swap the 2003 pcm with a 2002 pcm an this will fix the problem which i am setting in now but i havent done as of yet because parts are on order
Old Jul 3, 2012 | 12:10 PM
jlcress's Avatar
jlcress
pcm is a totally diffrent animal from 02 to 03 and not only is is the cranksencer diffrent the cam sencer is incorrect so 02 is 02 an 03 is 03
Old Jul 3, 2012 | 02:47 PM
darthroush's Avatar
darthroush
Section Moderator
If you read all of the previous posts in this thread, you'll find that information is already there. Hopefully you didn't find out by ordering the wrong year PCM...
