2003 SXT brakes
Old Jun 23, 2011 | 12:01 PM
cassie_elliott128's Avatar
cassie_elliott128
Question 2003 SXT brakes
The left rear brakes on my 03 SXT locked up the other night...started the car and began to back up and I was dragging that wheel along. A mechanic that doesn't know much apparently said it was caused by rust interfering with my calibers back there which would be great...if I had any. I'm not sure if it is just my car or not but I have drums in the back. Does anyone have any idea of what could be causing it and is it an easy DIY fix? Thanks!
Old Jun 23, 2011 | 04:22 PM
darthroush's Avatar
darthroush
Section Moderator
Since you have drum brakes, it could be a bad wheel cylinder. That's the "caliper" on drum brakes.
Old Jun 26, 2011 | 01:48 PM
xarkhun's Avatar
xarkhun
if it is a bad wheel cylinder its a real easy fix i did mine in 20min cost me all of $9.74 from napa.
Old Jun 27, 2011 | 12:43 PM
cassie_elliott128
thanks everyone for your suggestions! i ended up taking it to a mechanic to have all of the breaks just totally changed because my fronts were getting worn too. he said that something was wedged in that drum.
