Is front end alignment necessary
Old Jul 1, 2011 | 02:34 PM
Slim57's Avatar
Slim57
Default Is front end alignment necessary
after steering knuckle is unbolted, as in wheel bearing or mcpherson strut replacement?
Thanks.
Old Jul 1, 2011 | 04:21 PM
Matix151's Avatar
Matix151
there are no factory adjustments for camber on the strut so the answer is no. if the car has ecentric bolts for the strut mounting then you would have to mark where the bolts were before u took em out. in your case no an alignment is not required
Old Jul 5, 2011 | 04:12 PM
Slim57's Avatar
Slim57
Thank you.
