flash floood yay...
Old Jul 17, 2011 | 02:48 AM
dexi's Avatar
dexi
CEL is on - not flashing anymore. I will have to check for a shiny belt tomorrow.
Old Jul 17, 2011 | 04:23 AM
darthroush's Avatar
darthroush
Section Moderator
Get the codes!
Old Jul 17, 2011 | 04:53 AM
dexi's Avatar
dexi
I need a reader. :-/
Old Jul 17, 2011 | 09:29 AM
buddhaman's Avatar
buddhaman
Do the key dance. All you have to do is turn the key from the "Off" position to the "On" position 3 times in a row within 10 seconds. The third time you get to the "On" position, leave it there and the codes will show where the mileage is.
Old Jul 17, 2011 | 03:53 PM
dexi's Avatar
dexi
Hey, that's handy! Still only pulling emissions control small leak, now 2 separate codes, 442 and 456... However, now it won't start, won't even crank. I hear an electrical...something, almost the same sound as a window going up, for about 3-5 seconds while i hold the key down, before it gives up... Starter/spark plugs?
Edit: then again, i probably have several blown fuses.
Old Jul 17, 2011 | 03:59 PM
darthroush's Avatar
darthroush
Section Moderator
Yeah, start checking relays and fuses.
Old Sep 30, 2011 | 12:21 PM
dexi's Avatar
dexi
So here's what happened.
Took water in through the air intake. "Hydro-locked" a cylinder and bent one of my pistons.
Shop has to take the engine apart and replace the piston, valve something or other, valve cover, some ring, yadda yadda... Should I start planning my bank robbery now?
Old Sep 30, 2011 | 02:21 PM
darthroush's Avatar
darthroush
Section Moderator
If you aren't doing the work, yeah. Might be easier (and it will be cheaper) to find a used engine and just replace the whole thing.
Old Sep 30, 2011 | 03:52 PM
dexi's Avatar
dexi
--- Labor/Notes ---
$570.00 CYLINDER HEAD GASKET R&R M
Includes: Remove carbon, check surfaces for warpage, adjust valves and ignition timing.
$218.50 OIL PAN &/OR GASKET R&R M
w/Air Cond
$47.50 (Combination) CONNECTING ROD BEARINGS R&R M
One
$10.50 COMPLETE LUBE, OIL AND FILTER SERVICE
INCLUDES: CHANGE OIL AND FILTER. LUBE ALL FITTINGS ON STEERING LINKAGE, BALL JOINTS & DRIVE SHAFT(S). CHECK AND CORRECT ALL FLUID LEVELS TO INCLUDE
BRAKE FLUID, POWER STEERING FLUID, COOLANT, BATTERY ACID (UNLESS A SEALED BATTERY), AUTOMATIC TRANSMISSION FLUID. CHECK TIRE PRESSURE. INSTALL "NEXT
SERVICE DUE" STICKER.
--- Parts ---
$14.95 NAPA 5W30
$5.04 Oil Filter
$149.98 Oil Pan - Automotive Engines
$49.14 Oil Pan Gasket Set
w/ PermaDry Molded Rubber Gasket
$237.62 NBH Timing Component Kit & TFW Water Pump
$226.07 Cylinder Head Gasket Set
$65.00 WRIST PIN
$120.00 CONNECTING ROD AN BEARING
$85.63 PISTON
$34.50 HD LONG LIFE COOLANT
$15.25 PLASTIGUAGE
--- Charge/Misc ---
$84.00 Towing Charge
$2.00 Disposal Fee
$125.00 MACHINE CYLNIDER HEAD(S)
CHECK FOR WARPAGE, CLEAN, AND PRESSURE TEST
Note: M - Labor Database, Copyright, Mitchell International, All Rights Reserved
$846.50 Labor
$1,003.18 Parts
$0.00 Sublet
$35.00 Shop Supplies
$2.00 Charges
$91.19 Sales Tax (Tax @ $1,249.18 * 7.3000%)
$2,186.87 Repair Total
Old Sep 30, 2011 | 03:53 PM
dexi's Avatar
dexi
Anyone know what it would entail to just have them put a whole new engine in? Hey maybe I can upgrade to a better engine, eh??? :-/
