2000 Dodge Neon Trans
Old Jul 18, 2011 | 02:18 PM
markm2011's Avatar
markm2011
Default 2000 Dodge Neon Trans
I have a 2000 Dodge Neon my wife drove only about 10 miles and turn around yesterday with transmission fluid sprayed all underneath and side of the car I don't know where it is coming from can't find any connection.
Old Jul 19, 2011 | 12:00 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Check out the Neon Section!!
Dusty
Old Jul 19, 2011 | 05:32 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. My Coronet did the same thing and it was the breather tube,
FF
Old Jul 19, 2011 | 06:30 PM
buddhaman's Avatar
buddhaman
Welcome. Sounds like one of the hoses for the transmission cooler busted. If you look under the air box you will see a couple hoses that go from the transmission to the bottom of the radiator. Look around and see if one is leaking. If you have your wife put the car in drive and press the gas for a second while you're looking you should see fluid squirting if it is one of those lines.
Old Jul 20, 2011 | 12:35 PM
markm2011's Avatar
markm2011
hey' buddhaman,
you were right, one of the hose was rubbing against the metal if had cut into hose, thanks.
Old Jul 20, 2011 | 04:41 PM
buddhaman's Avatar
buddhaman
Glad it was a simple fix.
