Problem with my 05 neon code p0700
Old Jul 26, 2011 | 09:52 PM
keithman302005's Avatar
keithman302005
Default Problem with my 05 neon code p0700
I have been trying to get my girls 05 neon fixed for like 6 months I have code p0700 only I just changed the trans solenoid with no fix the check eng light came back on about 30 min later. whats is going on is when you come to a stop the its like the car doesnt want to stop and shifts hard and some times it wants to stall and has its almost like a manual trans when you forget to push the clutch in can some one please help me with this POS!!!!!!!!
Old Jul 26, 2011 | 11:24 PM
darthroush's Avatar
darthroush
Section Moderator
There are no other code besides P0700 (you must use a code reader to get the transmission codes; they won't show up in the cluster)?
Old Jul 27, 2011 | 08:11 AM
keithman302005
this is the only code the Auto Zone scanner pulls up and the car itself when you do the key on off deal then thats it. Will I need to take to the dealer and have them put it on the scanner. Is it not normal to have JUST P0700 code?
Old Jul 27, 2011 | 06:32 PM
darthroush's Avatar
darthroush
Section Moderator
The cluster will only show the P0700 code; it won't show any other P07XX codes which is why a real scanner is needed for transmission issues. I'll get back to this later though, I have to leave for work right now.
Old Jul 28, 2011 | 03:10 AM
darthroush's Avatar
darthroush
Section Moderator
Yeah, so anyways, the P0700 code means that there are DTC's stored in the TCM which must be read with a code scanner. If it does turn out that is the only code, which is not common, it is likely a computer problem.
