headlights?
Old Sep 21, 2011 | 04:47 PM
blazendizz's Avatar
blazendizz
Default headlights?
i can't get my headlights to adjust one is pointed up and another is off to the side im gonna die in the dark lol i tryed adjusting the 2 bolts but nothing happened its like there stuck in place and suggestions?
Old Sep 21, 2011 | 08:39 PM
leprechaun1874's Avatar
leprechaun1874
Take the headlights out of the car and make sure that the adjusters have the spring in them and actually turn.
Old Sep 22, 2011 | 11:51 PM
blazendizz's Avatar
blazendizz
were are the adjusters all i seen was the 2 bolts holding it on
Old Sep 23, 2011 | 12:57 AM
darthroush's Avatar
darthroush
Section Moderator
The two longs bolts hold the headlight to the car. The adjusters are on the back of the headlight. Usually one up top for vertical and one on the side for horizontal adjustment, although, it could be one unit too. I think the Neon uses a hex or torx. From there, follow the proper aiming procedure.
Old Sep 23, 2011 | 10:29 PM
blazendizz's Avatar
blazendizz
thanks man
Old Sep 24, 2011 | 11:17 PM
leprechaun1874
If you need, I can get some pics of the adjusters tomorrow.
Old Sep 24, 2011 | 11:38 PM
blazendizz's Avatar
blazendizz
if you can that would be great cuz i looked all i see is about a 5 inch thin rod idk if thats the adjuster but idk how to adjust it if it is and i didn't see and springs
Old Sep 26, 2011 | 01:36 AM
leprechaun1874
There are two 'tabs' on top that lone bolts go through and hold the light in place. The two bolt in the pic are the adjuster screws, you can use a socket or phillips head screwdriver.
Old Sep 26, 2011 | 01:08 PM
blazendizz's Avatar
blazendizz
thanks for the pics man but i think the screws are gone off mine and my headlights are different than yours to
Old Sep 27, 2011 | 12:29 AM
leprechaun1874
I didnt even realize yours was an 05. Mine is an 02.
