Door Lock latch/actuator
Old Sep 29, 2011 | 06:11 PM
Rtsitler's Avatar
Rtsitler
Default Door Lock latch/actuator
I think my power door lock actuators are shot, I want to call the junk yards tomorrow to get some used ones.
What i need to know is does each door have its own actuator and should i replace all 4 of them?
It seems the screeching noise is coming from the front doors.
2000 Neon
Thanks
Rich
Old Sep 29, 2011 | 09:50 PM
Rtsitler's Avatar
Rtsitler
nobody can help me out with this?
I am really hoping to get this fixed tomorrow....
Old Sep 29, 2011 | 10:39 PM
darthroush's Avatar
darthroush
Section Moderator
You answered your own question. If each door didn't have it's own, you wouldn't have to replace 4 if they were all bad.
Yes, every door on any car with power anything has it's own motor/switch/actuator. Each window on a car with power windows has it's own motor. Same idea applies.
Old Sep 29, 2011 | 10:44 PM
Rtsitler's Avatar
Rtsitler
Thanks for the info.... guess I knew the answer, just needed someone to confirm it for me.
It seems the rear door locks are working but the fronts aren't.... so looks like I will see about getting them replaced tomorrow.
Thanks again.
Old Sep 29, 2011 | 11:13 PM
darthroush's Avatar
darthroush
Section Moderator
Have you bypassed the switches with leads ("jump" the actuators) to make sure it's not a switch problem?
Old Sep 30, 2011 | 04:52 AM
Rtsitler's Avatar
Rtsitler
I'm not sure how to do that.
From all i have read the way they are acting and the screeching noise they are making points to the actuators being bad.
