Lightning Bolt warning light on Dash
Old Nov 12, 2011 | 01:14 PM
brent769's Avatar
brent769
As Darth says, it is just plug and play. Had to remove the screws on the side of the dash (open the driver's and passenger's door and you'll see a phillips screw). Then just lift the top of the dash (there are misc. clips) and then take the 4 phillips screws that hold the cluster in place.
I did not add the bulb in as the neon doesn't have an electronic throttle. Mileage stays with the cluster so make sure to write it down.
Old Nov 12, 2011 | 03:30 PM
rogerthat94's Avatar
rogerthat94
Thanks for the confirmation! I think I'm going to keep my stock cluster and add an aftermarket tach.
I recall reading that there was a tachometer that could splice into the wires for the cluster harness. Does anybody know of such a product? I would like to avoid having to connect the tach to the ignition coil or the PCM.
Old May 13, 2021 | 05:22 PM
Tom Thomas's Avatar
Tom Thomas
The lightning bolt means that your gas pedal is electronic instead of manual
