3rd plug cylinder
Old Oct 25, 2011 | 02:37 PM
krain88's Avatar
krain88
Default 3rd plug cylinder
ok so the cylinder for my 3rd plug to driver is raised maybe a 1/8" about the headgasket cover...the other three are fine. i was changing plugs and noticed it yesterday. There also is oil on the wire boot. Could that just be bc that cylinder has raised somehow? How do i push the cylinder back down i have tried to do it without removing the cover bc i didnt have a new gasket for it. I need to know how this can be done without going to a dealership b/c im low on funds thanks
Old Oct 25, 2011 | 04:00 PM
buddhaman's Avatar
buddhaman
The o-ring for the spark plug tube is probably messed up. It's a quick job and it cost around $30 for the valve cover gasket and o-rings.
Old Oct 25, 2011 | 04:55 PM
darthroush's Avatar
darthroush
Section Moderator
If the spark plug tube is raised, you could also try tapping the tube back in gently with something soft, like a piece of wood, and see if that fixes the problem. If not, then go pickup the VC gaskets and rings.
