Rear speakers only work when it is 100deg+ outside!!!
Old Nov 6, 2011 | 05:55 PM
Dilbert25's Avatar
Dilbert25
Default Rear speakers only work when it is 100deg+ outside!!!
So my rear speakers recently stopped working. However on days where it reaches 100+(TX) they work. Im not sure if its bad wiring or what but maybe someone else has had this problem or could help me, thanks in advance. It has original speakers but aftermarket headunit. Thanks
Old Nov 7, 2011 | 03:35 AM
73novass's Avatar
73novass
do you have an amp? if so its the amp overheated and the circute has a heat protection built in the amp and makes it shut down. Other then that I am lost why it would do that. Please forget everything I just said, I see that it only works when it is hot. Very strange.
