water in the floor
Old Dec 17, 2011 | 05:00 PM
jugbutt's Avatar
jugbutt
Default water in the floor
My son and his grandma both have Neons and they have a problem with water standing in the floor.
Does anyone have this problem and what is it from? thanks
Old Dec 17, 2011 | 06:33 PM
littlesmurf's Avatar
littlesmurf
could be from windshield, plugged a/c drain hose
Old Dec 17, 2011 | 09:00 PM
jugbutt's Avatar
jugbutt
but it is in the rear floor. would that matter?
Old Dec 17, 2011 | 10:25 PM
brent769's Avatar
brent769
Check your spare tire area. You most likely need to replace the tail light seals. My sister's car had the same problem this past summer, although it wasn't bad enough to go to the rear floor, just filled the spare tire well. The dealer has new seals for about $15 each. Also a good idea to use silicon on the tail light retainers.
Old Dec 18, 2011 | 03:24 AM
darthroush's Avatar
darthroush
Section Moderator
You should also gut the interior, IMO, to completely dry the insulation under the carpet out to prevent mold. Been there, done that. PITA but my car doesn't smell funny.
Old Dec 18, 2011 | 08:28 AM
jugbutt's Avatar
jugbutt
Thanks will try that
