05 sxt auto overheating
Old Dec 25, 2011 | 11:38 PM
krain88's Avatar
krain88
Default 05 sxt auto overheating
ok so this just happend. I was driving from ohio to florida and i hit about 250 to 350 miles and my car over heated. well it blew all my coolant out of the resevoir. well i thought it was the thermostat so i changed it when i got to my dads in georgia. I was on the way to my moms and once i hit the 150 175 mark it over heated again....what the heck could it be? i thought about my driver side fan bc it hasnt worked in over 7 months just didnt change it b/c car never overheated till now. could this be the problem? or what else can it be?
Old Dec 26, 2011 | 12:15 AM
steak59's Avatar
steak59
If the problem is the Fan not working, then u over heat when u sit at idle, but will not over heat when moving. Turning Heat on full blast also help cooling it down if problem is thermostat or Rad fan.
It could be a failed waterpump, or blown head gasket. Assume u have no coolant leak.
Old Dec 26, 2011 | 02:55 AM
darthroush's Avatar
darthroush
Section Moderator
Radiator cap good?
Old Jan 2, 2012 | 09:02 PM
krain88's Avatar
krain88
ok so i have replaced the cap the thermostat and descaled/flushed the radiator its running alot better and hasnt over heated yet....but the coolant lines still kinda have a roar to them?
Old Jan 3, 2012 | 03:30 AM
darthroush's Avatar
darthroush
Section Moderator
Roar...like there's air in the system?
Old Jan 10, 2012 | 08:20 PM
krain88's Avatar
krain88
yea i guess u can say that i mean it doesnt do it all the time. it will do it right when the car starts. then it will go away. its hit or miss.its just loud i think i have my system full. my res is full and i added a little more into the therno housing bc there was nothing there then i started the car and it warmed up and it pushed some out? i have no idea i dont think its a water pump problem i just dont know of anything else
Old Jan 12, 2012 | 05:58 PM
krain88's Avatar
krain88
Ok so my stupid car overheated again...no idea why. It didn't get to redline though. Neither did it do a coolant dump. But when I loosened my radiator cap it released the pressure and back filled the resevoir. Does that mean the new cap is bad?
Old Jan 12, 2012 | 07:47 PM
steak59's Avatar
steak59
no it does not, the rad cap suppose to hold some pressure.
do you have heat? does it help on the overheating issue if you turn the Heat to full blast?
here is another thing you can do. With the car running at Normal-Hot temp, feel the temperature at the Upper radiator hose, and then feel the temp at lower radiator hose, compare it. The lower radiator hose suppose to be A LOT cooler.
does your car ever overheat when driving on Highway speed?
it is possible that ur radiator is clog.
Old Jan 13, 2012 | 03:25 PM
krain88's Avatar
krain88
no i flushed the radiator thats what i thought it was. But i went and had it tested today and it is a blown headgasket. so i went and bought the hg set and some of the things i have no idea what they are for. now for the valve seals is it gonna be hard to replace them since i have the head out? and should i go ahead and replace them?
