head swap 2.0 to srt-4
Old Jan 2, 2012 | 02:08 AM
2.0bobmiser's Avatar
2.0bobmiser
New Member
Default head swap 2.0 to srt-4
i own a '05 neon 2.0 sohc ive done alot of research and i still dont know would i be able to swap it out with the dohc from an srt-4?
without any major mods?
Old Jan 2, 2012 | 03:58 AM
darthroush's Avatar
darthroush
Section Moderator
It is my understanding that you will have to modify the SRT head, along with changing other parts out.
Curious what you are looking to get out of the swap?
Old Jan 2, 2012 | 09:09 AM
2.0bobmiser
New Member
honestly i am looking to build a 2.0T dohc with a small budget and that seemed like a good idea
all i am asking is before i rip my old head off will oil and coolant passages from an srt head match the 2.0 block i will be using the srt intake and exhaust manifolds
another issue that crosses my mind is will the valves tap the pistons if left stock
Old Jan 2, 2012 | 03:26 PM
darthroush's Avatar
darthroush
Section Moderator
The SRT heads have a tear shaped oil passage on the rear I think it is. That has to be filled/plugged. I believe you can use an earlier 2.4 DOHC head and the oil passage will be the way it should be. From what I've read, sometime in 2002 is when it changed. You are going about it the right way and there are many people who have done the swap. This project is beyond me as I've never read much beyond the occasional post about it.
If you Google something like "2gn neon 2.0 to 2.4 head swap," you will find tons of threads from Neon places all over the internet about the subject.
Here's a thread from the 1gn section here with some information, as the 2.0s were the same. https://dodgeforum.com/forum/1st-gen...swap-info.html
Old Jan 2, 2012 | 04:17 PM
2.0bobmiser
New Member
thank you for the help
now it looks like im off to the junkyard to find a head and everything to make it work for some experimenting ill post what i find out about this
