About time to replace the timing belt
Old Jan 16, 2012 | 03:24 AM
dodgeyneon's Avatar
dodgeyneon
Default About time to replace the timing belt
There is no way that I am going to change it myself because it just seems way to hard for my mechanical skills. So my question is what else should be replaced when I have the belt change. I already know that I want the engine mount replaced because of the horrible vibrations in the car.
Old Jan 16, 2012 | 03:35 AM
darthroush's Avatar
darthroush
Section Moderator
Timing belt, timing belt tensioner, water pump, engine mount, cam seal, crank seal and the accessory belt tensioner pulley.
Old Jan 16, 2012 | 03:38 AM
dodgeyneon's Avatar
dodgeyneon
darthroush you are the man
Old Jan 16, 2012 | 03:40 AM
dodgeyneon's Avatar
dodgeyneon
oh i also forgot to ask if there are any suggestions as to where to get these parts for cheap
darthroush's Avatar
darthroush
Section Moderator
Thanks
Old Jan 16, 2012 | 03:42 AM
darthroush's Avatar
darthroush
Section Moderator
Timing belt kit (includes timing belt, tensioner and water pump)- $90
Engine mount- $27
The rest from your local parts store.
Old Jan 16, 2012 | 04:02 AM
dodgeyneon's Avatar
dodgeyneon
I hate to sound like an idiot and ask another question but what is the difference between the timing belt tensioner and the accessory belt tensioner pulley. (yes I am that much of a newbie)
Old Jan 16, 2012 | 05:27 AM
darthroush's Avatar
darthroush
Section Moderator
To keep it simple: the timing belt tensioner keeps tension on the timing belt. Accessory belt tensioner keeps tension on the accessory belts (the belts that run the alternator, power steering pump, A/C, etc).
