any ideas? 05 neon
Old Jan 17, 2012 | 10:24 PM
krain88's Avatar
krain88
Default any ideas? 05 neon
ok i took my head to the shop and i did blow my head gasket. it did warp and they are milling it .006 the max it can go bc you can only go .008 soooo i cant afford this to happen again. I dont want it to overheat again so i have flushed and descaled my radiator checked my water pump and it looked great. replaced the thermostat and radiator/thermo cap. any other ideas on what will make it over heat?
Old Jan 17, 2012 | 11:45 PM
ministock6's Avatar
ministock6
If everything is working, waterpump, thermostat, radiator flushed good, I would make sure the cooling fans are working right.
Old Jan 17, 2012 | 11:57 PM
krain88's Avatar
krain88
yea the driver side fan isnt working. i dont know if its the switch went out or the fan. Im gonna run a jumper wire when i get the motor put back together to see if that is it. I was debating replacing the radiator but i dont have the 200 but i also dont have the 300+ for a new head either lol so im just lost i hope its just the switch on the fan if so its a easy fix i will just run the jumper till i can replace it.
Old Jan 18, 2012 | 05:23 PM
73novass's Avatar
73novass
before jumping it turn on your a/c it should go on then.
Old Jan 19, 2012 | 03:05 PM
krain88's Avatar
krain88
I have only the ac fan kicks on the driver side fan doesnt
Old Jan 20, 2012 | 07:59 AM
73novass's Avatar
73novass
bad motor or relay or wirring, there is a temp sending unit as well to check
Old Jan 20, 2012 | 05:56 PM
krain88's Avatar
krain88
Yea that's why I was gonna run the jumper to see if it was the relay or actual fan
