Why do I keep getting error codes?
Old Feb 9, 2012 | 05:01 PM
MJSchutt's Avatar
MJSchutt
Default Why do I keep getting error codes?
Lately I have been getting lots of assorted error codes coming and going. A couple months ago I had O2 sensor codes, so i replaced my O2 sensors. Very quickly I got a 0032. I drove around with it for a couple months, having thrown away the old O2 sensor and not having the money to go out and buy ANOTHER new sensor. So the other day i got the money and bought myself a new O2 sensor, A new Camshaft Position Sensor (started to get a 0340), and a new Oil Pressure Sensor (oil light would occasionally come on even though I had just changed the oil).
I changed the O2 Sensor
now I get a 0132 coming and going
Changed the Camshaft Position Sensor
Getting a 0344 that goes away on occasion, but is on most of the time
After I changed it, the oil pressure light stopped going off, but by car will occasionally sputter, or will not respond when I hit the gas (Generally right after starting the car).
Didn't get a chance to change the oil pressure sensor (out of daylight) but did notice oil leaking from it.
i have also randomly been getting 0441, and 0550.
any ideas? the only thing i can think of is that there's a loose connection/ faulty harness, and i really don't want it to be that.
Any ideas are always appreciated.
Old Feb 10, 2012 | 12:16 AM
darthroush's Avatar
darthroush
Section Moderator
All the wiring is good?
Old Feb 10, 2012 | 12:21 AM
MJSchutt's Avatar
MJSchutt
Not sure. I don't really know where to start looking for that.
Old Feb 10, 2012 | 03:22 AM
darthroush's Avatar
darthroush
Section Moderator
Start at the two sensors you keep getting codes for and follow the wiring
Old Feb 26, 2012 | 02:46 AM
MJSchutt's Avatar
MJSchutt
Just a follow up, I took it into the shop where they replaced the aftermarket O2 sensors I installed Factory parts, and ran a Motorvac service on the engine. It runs better than ever! I cant recommend the Motorvac service enough, the difference is night and day. I have so much more power, and the engine runs SOOO much smoother. I am still getting the 0441 code, but im gonna go over all the lines this weekend. I'll let you all know what turns up.
