02 tranny
I have a 2002 neon and I need a new tranny (automatic) and for some reason I cant get a straight answer as to a 2005 neon tranny fitting? does anyone know if that would work??
The 2002 has a 41TE, which is a stronger version of the 2003-2005 40TE. The 40TE should work, it just won't be as "strong" internally. They are both an A604 Electronic 4-Speed. I'd go with the newest one you can find, simply because they update the solenoid packs as time goes on. You might want to consider having a TCM flash/update done just to make sure everything in the computer is kosher with the newer transmission.
