Need help with suspension 02 neon
Old Feb 21, 2012 | 08:42 PM
Nheal's Avatar
Nheal
Default Need help with suspension 02 neon
I'm new to the forum here and this is the first dodge i've ver owned but so far I love my neon. I just installed some poly bushings on my car and am now in the process of putting new struts and lowering springs on the car and am having a major issue with the front passenger side. the driver side went in flawlessly but the passenger side i'm having enormous problems with, the hub assembly seems to going out at a 45 degree angle what could cause this and how to fix?
Old Feb 21, 2012 | 09:39 PM
darthroush's Avatar
darthroush
Section Moderator
Is the no load on that side?
Old Feb 21, 2012 | 09:48 PM
Nheal's Avatar
Nheal
the whole front end is off the ground no load whatsoever on it just replaced the control arm bushings last night and now im working on this. I crawled under there earlier and noticed that one of the cv boots looks overstretched so im wondering if the halfshaft on that side may have partially slipped out and that is what is causing my issue. I've done the driver side front and both rear with absolutely no problems it's just this one side that is giving me issues.
Old Mar 20, 2012 | 06:28 PM
yokotaashi's Avatar
yokotaashi
Take out the other bolt and listen the 3 on top of the strut. Make sure the control arm is supported so its level. The two should fit together if you pick up the axle a little more, it looks right to me.
