01 Neon es Front end noise
Old Apr 6, 2012 | 01:56 PM
jord712's Avatar
jord712
Default 01 Neon es Front end noise
So this is the last issue I have to fix with this neon and it will be problem free. There is a noise that comes from the front end, but usually you can only here it when you hit a bump. Since I have had the car I have replaced both Front wheel bearings, both the front struts, and the outter driver side tie rod end, so I know that the problem is not in any of those things. What other things can this be? Would a bad ball joint cause this to happen? Could it be a lose mount? Any suggestions with a possible way to test it would be great.
Thanks
Old Apr 6, 2012 | 03:16 PM
darthroush's Avatar
darthroush
Section Moderator
What kind of noise is it?
Old Apr 6, 2012 | 03:25 PM
jord712's Avatar
jord712
I guess im not completely sure on how to explain it. Kind of like a dull klunk its not very loud. It kind of sounds like something is lose so something is moving around freely but ive looked under there and everything seems fine. I guess I could be missing something.
Old Apr 7, 2012 | 04:06 AM
darthroush's Avatar
darthroush
Section Moderator
From the Buying a Used Neon? thread...
Some sounds to listen for:
Squeaking and/or creaking while going over bumps- worn/torn lower control arm bushings or sway bar bushings.
Creaking while turning- worn outer tie rod ends.
Clunking while going over bumps- worn lower ball joints or sway bar bushings.
Old Apr 9, 2012 | 08:43 AM
jord712's Avatar
jord712
Ok thank you I will try those things next.
