o4 neon wont start after going into a ditch.
Old Apr 21, 2012 | 02:16 PM
slowsuby's Avatar
slowsuby
Default o4 neon wont start after going into a ditch.
my friend wrecked his neon into a ditch and now the car dosnt want to start. they starter dosnt turn over but everything else is working. the fuel pump comes on etc. there are 2 wires hanging down from the harness and im not sure what they go to.one black and one yellow. they look like they went into a plug but i dont see where a plug is that they could reach to and they are located by the clutch slave under the starter. there was also a harness plug that goes into a panel that has 2 other plugs going into it. it was the top one that was unplugged. plugged that back in. still nothing. i jumped the starter and the car turn over and still wont start. i also cleared the computer and still car turns over still wont start.
Old Apr 21, 2012 | 02:29 PM
slowsuby's Avatar
slowsuby
ok so kept messing with it and got it to start and still will only start by jumpind the starter.
Old Apr 22, 2012 | 02:22 AM
Moparkyle's Avatar
Moparkyle
Check for 12V on the S terminal on the solenoid, and check for 12V on the B terminal which is usually the larger wire.
Old Apr 25, 2012 | 05:48 PM
slowsuby's Avatar
slowsuby
Ok so what I figured out is that the car is cutting off the ground to the starter and fuel pump relay.
