CEL codes fix
Old Apr 27, 2012 | 04:45 PM
Oscar Sanchez's Avatar
Oscar Sanchez
Default CEL codes fix
hi
my 2001 neon has the following codes, how can i make them go away??
P1684 Battery Was Disconnected
P0340 No Cam Reference Signal at PCM or P0340 Camshaft Position (CMP) Lost
P0551 Power Steering Switch Failure
i have no clue what i have to replace to make them go away. or at least clear the codes to see if they come back on.... help!
Old Apr 27, 2012 | 06:32 PM
darthroush's Avatar
darthroush
Section Moderator
First one is a dumb code that means nothing
Second: likely either a bad sensor and/or wiring
Last: same as the other
